LFP Battery used from 2024
  • Found some infotmation regarding the "new" LFP modules in Rept battery used in AMI, Rocks & Topolino. Charging temperature is limited between 0 - 55 C° !
    REPT CB3914895EA‑50Ah – Technical Specifications
    ItemParametersTest / Note
    Nominal Capacity50 AhTypical @0.5C discharge
    Nominal Voltage3.2 VStandard LiFePO₄ cell nominal voltage
    Operating Voltage2.5 V - 3.65 VWorking voltage range
    Internal Impedance2.0 m (AC, 1 kHz)Typical fresh cell @25 ℃
    Standard Charge/Discharge Current0.5C / 0.5CStandard operating current
    Max Continuous Charge/Discharge1C / 1C (Pulse up to ~1.2C)Maximum sustained current
    Cycle Life≥ 7,000 cycles @80% SOHTypical @0.5C/0.5C, 25 °C
    Dimensions (L x T x H)148 x 65 x 95 mm.Typical prismatic cell size for REPT CB3914895EA
    Weight1.3 kgApproximate value
    Operating Temperature (Charge)0 °C to +55 °CStandard charging range
    Operating Temperature (Discharge)-20 °C to +55 °CStandard discharge range
