Alles anzeigenHas anyone ever looked at the existing heating system? What are the performance values? According to the feeling, there is a annealing in it...
If something reasonable could be installed, the problems would be elegantly solved and in the 12V electrical system.
Greetings!
Peter I'
Hi
The heating is 48V the control is 12V.
Beiträge von BaldyMan
Found some infotmation regarding the "new" LFP modules in Rept battery used in AMI, Rocks & Topolino. Charging temperature is limited between 0 - 55 C° !
REPT CB3914895EA‑50Ah – Technical Specifications
Item Parameters Test / Note Nominal Capacity 50 Ah Typical @0.5C discharge Nominal Voltage 3.2 V Standard LiFePO₄ cell nominal voltage Operating Voltage 2.5 V - 3.65 V Working voltage range Internal Impedance 2.0 m (AC, 1 kHz) Typical fresh cell @25 ℃ Standard Charge/Discharge Current 0.5C / 0.5C Standard operating current Max Continuous Charge/Discharge 1C / 1C (Pulse up to ~1.2C) Maximum sustained current Cycle Life ≥ 7,000 cycles @80% SOH Typical @0.5C/0.5C, 25 °C Dimensions (L x T x H) 148 x 65 x 95 mm. Typical prismatic cell size for REPT CB3914895EA Weight 1.3 kg Approximate value Operating Temperature (Charge) 0 °C to +55 °C Standard charging range Operating Temperature (Discharge) -20 °C to +55 °C Standard discharge range -
My experience is, that after several days with outside temperatures below 0 C°, the topolino does not charge, to be precise charging stops after few secounds when plugged in.Found some infotmation regarding the "new" LFP modules in Rept battery used in AMI, Rocks & Topolino. Charging temperatures limited between 0 - 55 C° !
Hi !
? si=GlekkerfCOcENXXExterner Inhalt youtu.beInhalte von externen Seiten werden ohne Ihre Zustimmung nicht automatisch geladen und angezeigt.Durch die Aktivierung der externen Inhalte erklären Sie sich damit einverstanden, dass personenbezogene Daten an Drittplattformen übermittelt werden. Mehr Informationen dazu haben wir in unserer Datenschutzerklärung zur Verfügung gestellt. -
