Based on some other materials it seems that the new Rept 6kWh LFP battery is using 1P16S modules instead of 3P12S structure in the E4V NMC batteries.
So one module capacity has to be apr 110-120Ah
When the PTC heater is ON, it uses apr 19-20 A from 48 V battery including the fan. I thik the heater must be around 900W
Alles anzeigenHas anyone ever looked at the existing heating system? What are the performance values? According to the feeling, there is a annealing in it...
If something reasonable could be installed, the problems would be elegantly solved and in the 12V electrical system.
Greetings!
Peter I'
Hi
The heating is 48V the control is 12V.
Found some infotmation regarding the "new" LFP modules in Rept battery used in AMI, Rocks & Topolino. Charging temperature is limited between 0 - 55 C° !
REPT CB3914895EA‑50Ah – Technical Specifications
| Item | Parameters | Test / Note |
| Nominal Capacity | 50 Ah | Typical @0.5C discharge |
| Nominal Voltage | 3.2 V | Standard LiFePO₄ cell nominal voltage |
| Operating Voltage | 2.5 V - 3.65 V | Working voltage range |
| Internal Impedance | 2.0 m (AC, 1 kHz) | Typical fresh cell @25 ℃ |
| Standard Charge/Discharge Current | 0.5C / 0.5C | Standard operating current |
| Max Continuous Charge/Discharge | 1C / 1C (Pulse up to ~1.2C) | Maximum sustained current |
| Cycle Life | ≥ 7,000 cycles @80% SOH | Typical @0.5C/0.5C, 25 °C |
| Dimensions (L x T x H) | 148 x 65 x 95 mm. | Typical prismatic cell size for REPT CB3914895EA |
| Weight | 1.3 kg | Approximate value |
| Operating Temperature (Charge) | 0 °C to +55 °C | Standard charging range |
| Operating Temperature (Discharge) | -20 °C to +55 °C | Standard discharge range |
My experience is, that after several days with outside temperatures below 0 C°, the topolino does not charge, to be precise charging stops after few secounds when plugged in.Found some infotmation regarding the "new" LFP modules in Rept battery used in AMI, Rocks & Topolino. Charging temperatures limited between 0 - 55 C° !
Hi !
